Old 02-12-2008, 04:46 PM
traindriver traindriver is offline
Cobra Make, Engine: SPF #1591 / Perf.Eng. 351W/48IDAs
Default Weber Linkage
GatorAC,
I have a linkage plate for a 351W IDA setup available..someone had ordered it and changed their mind.
The under the manifold method for power brakes is not that hard, i used 1/4" copper tube with compression fittings, tapped into all 8 runners. The only part that was not off the shelf was the feed thru at the back wall of the mainfold. I had to drill out the NPT to AN6 fitting and solder in a piece of copper tube to connect with the tubing network. No big deal.
I autocross my car on occasion, and have never felt any lack of boost in the brakes.
Chuck
