Old 02-12-2008, 06:19 PM
Shelboss Shelboss is offline
Cobra Make, Engine: early Contemporary Cobra (1005), 67 Shelby GT350 with Inline carb on a Boss 302
I talked to the Koni rep who says the shock would have to be dissassembled to slip the threaded sleeve over the lower tube. If anyone has done this, can you measure from the bottom of the tube to the lowest position the spring perch will sit at? The stock lower spring perch is 1.25" so either the sleeve will have to extend further down or shorter springs used. Stock springs are 11" length, I would not want to use shorter than 10".
