Old 02-14-2008, 05:40 AM
1966plus's Avatar
1966plus 1966plus is offline
Question FE flywheel bolt pattern
Hi Guys,
another techie question for you.
Does anbody know the correct bolt pattern on an FE flywheel/crank? My flywheel from KEP has 2 holes at a slightly different radius from the other 4, whilst my crank (supplied on a built engine from Huddart Engines in the UK) has all 6 holes at the same distance from the centre. No matter how the flywheel is rotated only 4 holes will line up!
Which of these is correct for the FE? The flywheel will have to be modified whatever the answer, I would just like to know who has sent the correct spec part?
Craig
www.miragemk2.com
