Old 02-14-2008, 01:03 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
If you doubt what damage a flywheel or pressure plate can cause when it comes apart at high rpm, look at the photo. I was called into court several times as an expert witness in cases involving an exploded clutches/flywheels. These ranged from clutch failures in a dump truck to a Top Fueler. One severed foot; the other a floater plate went through a lady's shoulder while she was sitting in the stands. If you're doing any high-horsepower, high-rpm driving, use a scatter shield, especially with a conventional clutch. Tilton and Quarter Master small-diameter clutches aren't nearly as dangerous.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
