Old 02-15-2008, 01:58 PM
J Persons J Persons is offline
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
Originally Posted by jdean View Post
J Persons, the loss from the drivetrain is not speculation, but has been proven with countless comparisons of FWHP compared to RWHP on the same engine. The ZF transaxle is not a fair comparison since it is both the transmission and differential in the same unit, so it is intrinsically more efficient vs a transmission, driveshaft, differential.
The chassis dyno vs engine dyno sometimes introduces sources for addition losses like exhaust systems or other accessories driven by the engine.
True, but I was using the referenced ZF as an example only. If the 20% is correct, that would put my 331 at around 420 FWHP, and I just don't think it develops that much power. If someone on the board is a Ford power train engineer, they could answer and put this debate to rest.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
