Old 02-17-2008, 12:45 PM
blykins blykins is offline
Yes, you can also use a product called "Right Stuff". BTW, use sparingly. A little dab on the corners where the cork meets the heads is good...you just need a small bit to fill the crack and seal the joint. When you put some around the water ports, use a very light coat...almost like a coat of paint. People sometimes get carried away with RTV and it just looks messy...plus it increases the chance of some falling into the lifter galley or into the ports.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
