Old 02-18-2008, 05:45 PM
RedBarchetta RedBarchetta is offline
Banned
Depends on the set-up (tire and wheel profile, shock settings, stock bellhousing or blowproof, cut or not cut, oil pan, etc.). Figure 4.5" of clearance on average. Some here have reported a little lower, some a little higher (+/- .5 inch). Also check the front oil cooler surround ('glass) clearance...usually about the same. Oil cooler shroud, oil pan and transmission bellhousing will be your three lowest points of potential contact.
-Dean
