Old 02-19-2008, 07:10 PM
mikeforte mikeforte is offline
Hi,
I've built a few new BOSS blocks. The steam holes that I know of are the between each of the cylinders in an "X". If you look between the #1 & #2 (between all cylinders too) cylinder there are triangular shaped holes that will expose the steam holes that will cris-cross about 2 inches down. No drilling or machining is needed.
These steam holes limit the max bore size because the limit the material between the siamesed bores.
I hope this helps some.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
