Old 02-19-2008, 11:24 PM
Keithc8 Keithc8 is offline
Default Heads
The Edelbrocks will flow better than what he has there is they have the correct valve job done to them. You also end up with an aluminum head which is a lot easier to fix if there is a problem in the future not to mention the 40 pounds or so that you save in weight.
I have a real nice set of the C3 castings that we have ported and installed the 2.099/1.660 valves in with hardned seat and all but I would have to get 1500.00 for them because of all of the labor. If someone wants to stay with a factory steel heads these would work great. Good luck, Keith
Keith C
