Old 02-20-2008, 04:33 AM
DAVID GAGNARD's Avatar
Mike;
That's what I thought also at first, but look at the first picture in my post and you'll see a very small (3/16 maybe) hole on either end of the block just inside the head bolt hole,that is also a "steam hole"....that's the one I was worried about.....OEM factory blocks, at least the early ones I have do not have these holes.......
My heads do have the holes that line up with the small outer hole on the block....
BTW: what head gasket (part #) did you use on the BOSS 302 builds?????
Thanks;
David
DAVID GAGNARD
