Thread: Ford rear end
Old 02-20-2008, 06:50 AM
Philm's Avatar
Philm Philm is offline
Default History unknown
HI Alffie,
The diff was second hand when I bought it, had a limited slip center installed and all was good.
I then changed the ratio to 3.9 and that only lasted about 6 months of hard work (factoring in when it was on stands).
The 3.9 gear set were second hand so maybe they were not the best, the new set are a later model version and are better, not by much but better.
The Au will be ok if you are just putting arround even curcuit work will be ok, it is the hard launch on a drag strip that will test the strength.
Phil
