Old 02-20-2008, 11:06 AM
khansmith's Avatar
khansmith khansmith is offline
Cobra Make, Engine: Hurricane Motorsports, Southern Automotive 428 FE
LPG is very interesting. Since you can run a dual set up (gas and LP), one could have a primary LPG tank (also seems that it could be same size as gas tank) and a spare/emergency gas tank "just in case" you can't find LPG...help you limp to your destination.
On the other point, if you had EFI on an FE engine today, could you set it up to run on less cylinders when cruising?
Hurricane Motorsports: HM1046
Follow the build on my blog: http://khansmith.blogspot.com/
1974 Pantera resurrection blog:http://1974pantera.blogspot.com/
