Old 02-21-2008, 10:13 PM
bigrob's Avatar
bigrob bigrob is offline
Cobra Make, Engine: BDR # 126/ K. Craft 306 CID/375 HP- 306 RWHP
Originally Posted by SoTxButler View Post
Should be. I am going to build a bracket to bolt onto the MC. The two bolt holes will be slotted so I can loosen the MC and slide the mounting side of the bracket on between the bolts and the MC. Then, I will take a half moon out of the stop side of the bracket so the rod can move through back and forth. The stop side of the bracket controls the throw of the rod when the the pedal bumps up on it. In my case, it will be about 1" off the MC and that is the point where the clutch disengages.
I will post a pic when I get it done. But, since it works so nice, it will be a little while. I have only made a cardboard pattern at this point.
Sounds cool Russ!
Rob
" Listen to that music! "
'65 BDR #126
'84 Porsche 928S
'01 Corvette C5 coupe
'99 Ford Explorer Limited
