Thread: Stiff clutch
Old 02-22-2008, 11:47 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Start by lubing the cable. Go to a motorcycle store and buy a spray can of Chain and Cable lube. Disconnect either end of the cable, and clamp it to the hood. I prefer to disconnect the pedal end, so excess lube fall on the ground and not on the carpeting. Spray the lube into the cable sheath. Do it a number of times to ensure it gets lubed well. Let it sit like that overnight so the lube will flow to the other end of the cable. Reassemble.
If that doesn't work, consider replacing the cable.
