Old 02-22-2008, 12:39 PM
Juggernaut's Avatar
Juggernaut Juggernaut is offline
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
Question Getting ready to fill the cooling system but have a question
I've done the searches but have one question (hopefully not a stupid one)concerning the procedure below that I got from a previous post on the forum:
Open the filler cap and fill everything thru the intake. Use a nice size funnel, take your time and lay rags on the motor etc to keep things neat. You will hear all the air leaving your motor AND rad thru the filler as the coolant rolls down the lower rad hose filling both rad and motor. Close up the intake plug when full. Top off filler . Start for one cycle. I then needed to top off the filler by adding 6-8 ounces.
It says to 'top off the filler and start the engine. I would imagine the filler neck cap should be on when the engine is started or bad things will happen, right?
Randy
Juggernaut
