Old 02-22-2008, 08:07 PM
Tangible Toys Tangible Toys is offline
Cobra Make, Engine: Backdraft #520, 302 FORD racing Z50Z,t-56,391 posi
Originally Posted by bigrob View Post
Anyone using a clutch pedal stop? It seems like there should be one to avoid overuse & wear on the valve in the master. I would much rather the pedal stop from a stationary stop than the valve bottoming out! Probably could rig somethng & attach it to the lower mounting nut & bolt.
Hey bigrob,your car should have a tab welded on the clutch pedal,simply put a fully threaded bolt with 2 nuts one on each side of the pedal.Adjust the bolt against the fire wall with enough travel to release clutch.
Wayne Pontes & Mary Ann McAlinden
http://tangibletoys.com
