Old 02-24-2008, 03:51 PM
rcweingart rcweingart is offline
Cobra Make, Engine: SPC Brock/Shelby Cobra Daytona Coupe 51, Roush 427IR, also full custom 600+ HP Austin Healey and Ferrari Daytona spyder
Hey Rick, the point I use for the rear jack joint is right at the edge of the sheet aluminum covered bellypan right in front of the rear tire and just aft of the side pipe tips. The edge runs diagonally outboard from the center rails and is pop riveted to a square tube - which is really what you want to use. The trick is to get your jack squarely centered under the square tube as close to the main rails as you can. Use something to protect the aluminum from the jack and you may have to use a spacer. As for the front jack point, you will probably be coming in from behind the front wheels so you will have to reach far enough in to pick up the main frame rails and will have to make sure your jack is securely positioned so the main tube doesn't slip off. Ron Weingart
