Old 02-27-2008, 04:45 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Ignition Advance ?
I have chosen to use a Mallory Unilite distributor on my FE 3x2 setup. The unit had vacuum advance but when I sent it in to have the crab cap conversion for air cleaner clearance, the vacuum advance was history. Not enough room/metal for both.
I intend to use the car for road trips. Knowing the FE isn't going to win any awards for fuel mileage, I am still after all I can get.
I've had the thought of adding an electronic timing adjuster to allow "dialing in" a few degees advance when cruising. Will I improve mileage any amount by doing this or am I chasing dreams?
The timing adjustment would run about $120 and allow about a 15 degree adjustment from the cockpit.
Paul
www.65shlb.com
www.prdcrrct.com
