Old 02-28-2008, 04:23 AM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
Many replies are trying to help figure out why the engine will not fire up, ie maybe the coil, maybe the MSD box, maybe. If I understand the situation correctly, the engine does not crank over. When trying to start, it goes "click". It is very difficult to diagnose an ignition problem when the engine cannot be cranked.
Therefore, the first step must be to check the battery, the cables, the cable connections, and possibly even the starter (I don't think that the starter is a problem since it did start by boosting it with the old battery). The first step has to be the cables and those new connectors. As already mentioned, make sure that the cables are properly connected to the battery and that the ground is clean.
Have you spoken to the person that sold you the car? If not, give him a call and ask if there were any other starting problems other than a bad battery. Get it cranking over, then worry about any other problems you may have caused by reversing the polarity.
Wayne
Don't get caught dead, sitting on your seat belt.
