Originally Posted by Murphy
You need a jumper wire between the large terminal on the starter that your positive battery cable is connected to and the small flat tab terminal on the starter just below it.
Murphy, thanks for the reply. I believe I have done what you have described. There are only 2 posts on the starter the battery and the ignition posts. I have run a wire between those two posts.
In order to make sure my starter is okay, I placed all wires on the hot post of the solenoid and as soon as I hook up he battery the starter engages (thus bypassing the switch).
I can't tell you how much I enjoy electrical
