Old 03-02-2008, 03:54 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
You don't say what rear end is in your car. If it is a Ford 9" rear, the 11" disc brake setup from a 1978 Lincoln Versailles should most likely fit. The Lincoln rear is a 28 spline model that uses 11" disc brake "hats" and calipers with built-in cable operated emergency brake. That's the setup I use and it has worked like a charm.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
