Old 03-03-2008, 07:23 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Gas40,
If you don't have a tube that bolts onto the firewall and the clutch sleeve/nylon beaing fits into then a simple 1/2" (?) tube works great. Shower curtain rod, towel rack rod, etc will work great. 4-/2" long to 5-1/4" weld a plate on one end allowing enough room for the cable to go through without hitting the tube, drill a hole on each end to put bolts through and you have it. If you really want to make it easy weld two 1/4x20 studs on the flange and simply drill a hole in the firewall for the cable and one 5/16's hole on each side and then bolt it on that way. Clear as mud? Take a look at a picture of one and it all becomes quite clear.
DV
