Old 09-13-2001, 05:10 AM
dmfconsult dmfconsult is offline
Default Sending Unit
Don, since I did not assemble my Cobra I'm not sure of the source of the parts. I am assuming that the tank and sending unit is what CRL provides. The I.P. consist of the VDO "Cockpit" kit.
When I received the car I was told that included with it is the correct sending unit provided by VDO (which has to be installed if I wanted a correct gauge reading). I removed the tank and the FSU (fuel sending unit) assy. I found out that the VDO assy did not provide an outlet to draw fuel from like the one I removed, further, I found the the physical size of the VDO FSU would not fit into the tank opening. So I'm wondering what sending unit should go in there. Was the CRL FSU defective or is the resistance ragne incorrect. I have asked VDO for the specs. on their gauge but they do not respond. Is anybody else using VDO with the CRL FSU? The tanks 19 gal.
Dave
