Old 09-13-2001, 05:19 AM
Dominik's Avatar
Dominik Dominik is offline
jack,
just make sure that you crimp before soldering, because the solder has a tendency to float if pressure is applied (do not crip after soldering).
but you wrote it that way.
in addition to that i prefer to use a ground cable from the battery to the starter and make sure that it is thick enough.
i am not familiar with "gauge" as the indicator for the thickness, but if you measure the copper's diameter: 7/16" is plenty.
dominik
If I don't respond anymore, that's because I can't log in
