Old 03-04-2008, 03:18 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Toe in "is" adjustable,it just takes a little time to do it. The shims behind the lower control arm mounting plates on the diff,adjust your toe in. Once that is all done I recommend installing track rods to control the flex in the lower control arm.Have a look in my gallery and you will see what I did. The reason that i faced them towards the rear is because that way the are longer No1, and 2, they are in tension as opposed to compression so you can use a lighter rod. Also if you use left and right rod ends you can get a little fine tuning on the toe in.Ihave driven and raced my car like this for 50000miles with no hint of a problem.
