Old 03-07-2008, 05:27 AM
Default Matt, what are you trying to do??
FIA-ERA Matt what are you trying to do? Call ERA, they can mail you a Ign. switch and keys. You could have them tomorrow. Matt Go to the ERA site. All the info you need is there with the numbers. If you have the wiring harness from ERA , all you have to do is remove the whole dash assembly, swap over the wires and reinstall. Drop the steering column first, it's easier to flip the dash in the car. If you add any other curcuits for whatever, Make sure you use heavy duty relays, 30A are OK for most curcuits, 40A is better. Put a fuse on the curcuit that is about 15% more than the component uses on high speed or on position. Water proof connectors for the fuses help. Rick L.
