Old 03-07-2008, 03:49 PM
Maurice Johnson Maurice Johnson is offline
Another way would be to use an adequated fused relay ( with it's separate power supply) to power each pump, and let the switch parallel power the relays. Use a 12g wire on the switch circuit, and you shouldn't get much of a voltage drop. This is how we switch on field current when running 2 big alternators on marine engines.
