Old 03-08-2008, 02:01 PM
blykins blykins is offline
It all depends on how big of a step there is between the intake and the head. Generally, I use a cork gasket, put a little RTV on the joint between the head and intake, then smooth it out so that it takes the step out. Try to make it a smooth transition, so that they are level with each other. I don't use any adhesive at all on the gaskets and just tighten them by hand.
It also helps if the heads don't let the oil pool in the top end.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
