Old 03-09-2008, 12:21 PM
John-Tucson's Avatar
John-Tucson John-Tucson is offline
Lonestar #024, Thank you for the offer. About a month ago I gave my computer to another Cobra owner and he gave me his older style one. I drove home after the swap and started cutting out the old computer wires that I didn't need, the Cobra is carbed now. I checked that the electric system was working after I cut each wire, I turned the key ON and the fan came on and lights, so I continued to cut. On the second day I tried to start the car and after a few attempts I realized that there was no fuel pressure or fuel in the carb. It would start but not run when I poured gas into the carb. I have traced the wire, red/black, from the fuel pump to the inertial switch and forward into the back of the dash. I have not been able to find the fuel pump relay, that is what I believe I need to find and check for correct operation. The wire disappears behind the dash and into a bundle of about 20 wires and I can not find it coming out. Basically I have been lying upside down in the drivers footbox with the flashlight in my mouth and one hand in the bundle of wires trying to trace the wire. Oh, yes, I even went and reconnected all of the wires that I'd cut and installed the computer. If you do have the day off on Thursday I'll buy lunch if you can help me. I live in Catalina. #520-825-9197 PS. Your radiator will be late, Dale has dropped to 30th.
John
