Old 03-09-2008, 05:54 PM
Default Find another rearend
Scufty I ring and pinion for that rearend is in the $4-600.00 range. If the tooth is not in the case, The guy before you knew he damaged the gears. The only thing I can tell you is go to swap meets ot junk yards and look for another jag rearend. You only need the center section. What gear ratio is it? May sure that you get about the right year for the center case. The mounts changed for the caliper and parking brakes.You should be able to fine a whole unit for about $3-500.00 dollars. Jag gears are different from dana 44 gears even though they use the same basic case. I did install a locker from a dana 44 in jag case but had to enlarge the bolt holes from the ring to fit the new posi. Rick L.
