  #36 (permalink)
Old 03-11-2008, 09:47 PM
400TT's Avatar
400TT 400TT is offline
Originally Posted by ptrefry View Post
So after all that I quess the answer to my question is, no, no one knows what will fit.
Paul, have you been reading the posts.
Wilwood definitely fit jag front-ends.
Skyline definitely fit jag front-ends.
Both can be found and sourced with bolt-on adaptors if you look hard enough.
Hi-Spec look good, but are a lot more expensive than the options above. But sounds like they fit as well.
With wheels, I don't think you are going to have any problems with wheel centre clearance due to the jag hub -> rotor face offset.
Just make sure you don't have any issues with clearance due to specific front setup on your Cobra, I wouldn't expect so.
www.absolutepace.com
