Old 03-12-2008, 10:34 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Often this happens when the connection at the battery is not good. IE the cables. So it allows enough current to run all the stuff but as soon as you load the system it basically shorts.Could also be a bad ground cable connection either at the block or at the frame.You have more than one ground cable I hope??
John
