Old 03-12-2008, 10:48 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Terry,
The pin snaps were supposed to follow a patern, which I will try to duplicate, BUT each top had the rear snaps a little off from car to car. With luck no filling and re-drilling would be necessary, but then again....(Don't fill/re-drill unless necessary!)
DV
P.S. if you have a standard sized 4-point roll bar from side to side then you probably don't even need to use the bows. The long roll bar really works well!
