Old 03-13-2008, 07:50 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
If you want to straigten out your engine yourself----take the Webers off and put on a Holley 3310 carb---when you get the engine running right, then change to the webers if you still want to run them. And while you have the manifold off put a cam in it that has only about 560-580 net lift and reasonable duration so that it'll runn below 3500 rpm
Jerry
