Old 03-13-2008, 12:42 PM
DAVID GAGNARD's Avatar
[quote=wtm442;824455]After replacing plugs, if you still have problem, take off the dizzy cap and wipe the inside so its clean and dry. Maybe some moisture inside. Then start engine inside garage with all lights off and cover any windows ... any sparks jumping from the wires?[/QU
zacctly, I've found with MSD distributors, the contacts on the inside of the cap corrode quickly and easily when left sitting for long peroids.....take off the cap and hit each connection with a small wire brush as well as the rotor, blow dry the inside of the cap and try it again...........at night...........
David
DAVID GAGNARD
