Old 03-14-2008, 03:25 PM
slithering slithering is offline
Cobra Make, Engine: Midstates, Genesis 427 S/O
Will your fan normally work without the ignition in the on position? Are the post in the battery removable, if so remove and clean. You might replace with an anti-oxident compound like Nolox or Penetrox, they prevent oxidation on electrical connections of aluminum and copper or aluminum with copper. Check all grounds and their connections.
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
