Old 03-15-2008, 04:12 PM
Velox Velox is offline
Cobra Make, Engine: SPF 545" stroked 460 - sold
JB the stock SPF has the Ford regulator mounted up under the left front fender, and the stock system would not have a one-wire alternator. If you in fact do have a one-wire system, then the stock regulator has been disconnected and perhaps just left there for whatever or future use with redo of a stock setup. I converted mine to a one-wire alt, and removed all the old wiring and Ford regulator. If you have a one-wire alternator, it would be obvious, because it has... one wire on it, not the usual harness connector. The SPF also (stock) ships with an ammeter, not a voltmeter. I have converted mine to a Smiths voltmeter, is that what you have in your dash? If so, it reads up to 17V. If you pegged that, your system was putting out 18V or more, highly unlikely, but meters do go bad. I would think you need to check the actual voltage with a good digital meter at the alternator post when the engine is running and your gauge is pegged, that will tell you for sure what the system actually is at. If really that high, your one-wire alternator's internal regulator would seem to be toast. If reads normal (13 or 14V or so) running, then your voltmeter is the problem - lose wires, ground, whatever. If you really have an ammeter, and THAT is pegged, that is an entirely different problem, flowing that much current through the system big trouble, just my thoughts FWIW
