Old 03-15-2008, 03:41 PM
Texas-Saluki's Avatar
Texas-Saluki Texas-Saluki is offline
Cobra Make, Engine: JBL - TK0600, Electromotive EFI, Keith Craft 408W "standard crate", ~575hp
Send a message via MSN to Texas-Saluki Send a message via Skype™ to Texas-Saluki
Originally Posted by Rwillia4 View Post
What weight oil are you running? where is your oil PSI gauge located on tne engine? what is the P?SI at start-up?
It is 20W-50...as for where it is located... I think the normal pickup location??
Originally Posted by vector1 View Post
i had the same problem with my engine on the cobra i bought. get a leakdown tester and check your cylinders. that'll tell you real quick. on the pressure thing 25 at idle won't hurt, you just want more when the rpm's pick up.
I just finished my compression test and all of the cylinders are between 150-140 so it does not appear to be a head gasket problem
Chris Noland
JBL
Flower Mound, Texas
http://www.thenolands.com
www.txcobraclub.com
