Old 03-15-2008, 09:16 PM
cobrajam's Avatar
cobrajam cobrajam is offline
Cobra Make, Engine: Contemporary frame, Midstates kevlar body, Aluminum Shelby 427, G-force T-5
You may want to run it thru one of the numerous calculators out there. Do a search on 'Carburetor CFM Calculator'. I pulled up one, set up your 482ci, 6700rpm, pulled up a 935cfm requirement at 100%ve. Which is almost exactly the same as mine, 430ci, 7500rpm.
Great to see after all the work making room for an FE, you are going to stick a KC sideoiler in it. I would recommend a port matched Edelbrock Victor w/ the 4bbl. Polish up a turkey pan and stick under when you want the looks. What roller are you going with?
