Old 03-16-2008, 02:51 PM
BMK's Avatar
BMK BMK is offline
Alfie
They look good. The corkscrew insert will re direct back into the sides and should reduce the noise.
Summit racing have a pyramid dome that is an insert that also reduces noise, check their exhaus/muffler section out. - if you find you are too high in the dB readings. The insert does not reduce flow as the surface area is greater than the internal measurement of the pipes
www.summitracing.com
Bernie Knight
