Old 03-16-2008, 04:08 PM
Keithc8 Keithc8 is offline
This is either the brushed or polished aluminum car with the opposite stripes, visors, side vents, wheel foam, complete oil coller system, Kikrham billet aluminum hydraulic clutch linkage system, side pipes, billet engine and trans mounts, wool carpet, trunk mounted battery, billet over flow tank, larger front brkaes, Penske shocks, billet lift jacks, all aluminum 482 FE engine with TKO 600 transmission, bell housing, McCloed flywheel, clutch and pressure plate, billet shifter, drive shaft with installation, set up, alignment, tuning and test driving for at least 50 miles to check all items. The engine is dyno tested before installation and tuned after installed. There are a few options I probably forgot to list. Feel free to call with any questions. Prices will be going up on next shipment of cars. Thanks, Keith
Keith C
