Old 03-16-2008, 04:16 PM
Keithc8 Keithc8 is offline
We do a Pond 482C.I. FE engine from carburetor to oil pan for 16,500.00. If you add the pulleys, brackets, alternator, belt, flywheel, bell housing, clutch and pressure plate, starter, TKO 600 transmission, Kirkham hydraulic clutch set up, shifter, alignment, fluids, installation and all you will spend about 25,000.00 to 27,000.00 depending on some options. Give us a call for a complete quote for your application. Thanks, Keith
Keith C
