  #23 (permalink)
Old 03-16-2008, 07:32 PM
My427stang My427stang is offline
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
I'd run a 950 HP as a minimum, but would advise you go with a 1000 HP Holley or an 850 Barry grant or 850 QFT
The 950 is a misnomer, its a 750 with an 850 baseplate and isnt a very big carb for what you have.
I run an almost identical 489 FE in my 3500 lb Mustang, with an almost identical running gear and run an 1000 HP series carb, it is very streetable and very much not fussy.
The 1000 is actually dimensionally the same as an 850 asides from a shaped entry area, and remember an 850 isnt out of place on a heavy 454 or 460 with an automatic in a full size car or truck. I promise you have enough motor to happily use a good 850-1000
The 950 is a good carb, but it is smaller and will lose top end charge, but gain you nothing down low over a modern 850 or 1000 HP.
1994 ERA Cobra, 452 side oiler, C5AE-F, Tunnel Wedge
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
