Thread: Wiring??
Old 03-16-2008, 10:39 PM
Maricopa Maricopa is offline
Cobra Make, Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
Send a message via AIM to Maricopa
Sawee, just saw this. Finished up today and fired her up. Still need to set the timing and futz with the carb but it sounds good. It immediately developed a leak at the water inlet (folded over the stupid gasket) so I fixed that and then went looking for something to plug the no-longer needed O2 bungs. No luck on the bung plugs (insert joke here) so I stuck the sensors back in for now.....Then, after all that I discovered that the left rear turn and brake light had quit working. All the rest of the signals are fine, I have running lights front and rear and the driver's brake light is fine. Bulbs were good so it's in the wiring somewhere.
Ain't ya glad you asked?
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
