Old 03-18-2008, 11:22 AM
NJBIGBLOCK NJBIGBLOCK is offline
Use a DC voltmeter to check for a voltage drop between the engine and the car chassis.You should not get a reading with the engine running and your accessories on.(lights,radio,etc) If you do either add another ground(if one is not enough) or correct the connection on the existing one. I had a simular problem once and that was it.
