Old 03-18-2008, 11:55 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Hey, Dan...how's it hangin'...?
I've not had any direct experience with removing the factory-installed liners, but I would suspect they're stuck on with a rubber-based contact glue...same stuff as Top of the Hill uses on their pre-cut padding. Most times, using something like a heat gun to heat and soften the adhesive works well to help loosen its grip. Then, once removed, use something like lacquer thinner or acetone to clean the rest of the glue off....watch the fumes and use protective rubber gloves...both of these will eat your hands UP! Also - DO NOT - repeat, DO NOT - let either lacquer thinner or acetone get on your paint!!! I don't need to tell you what either one of these will do to your painted surfaces, do I...?
Then, wait for everything to dry....you'll still leave some glue behind, no doubt...wait overnight, if possible.
Then, it's just a peel and stick application after that.
I found that the stuff works best - for me, anyway - by peeling only about a half of the paper backing off, then position one of the edges of the piece where it needs to be...then stick it down and continue slowly peeling off the backing and sticking it down as you go. Be careful not to get an air bubble under it as it will pull loose from the inside of the fender later on....ask me how I know this....go ahead, just ask... Also, I used a small wooden wall paper seam roller to roll down my liners...worked well.
Hope this helps...
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
