Old 03-18-2008, 08:00 PM
My427stang My427stang is offline
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
I personally think that going too small on a dual plane is giving up a ton of mid and upper end without gaining anything down low. In the very least try both, dont just go small, you have a serious motor
A single plane with a large plenum may be a different story, easy to overcarb and they can be a bit fussier down low, but a dual plane needs as much airflow as it can get, any one cylinder is pulling from a plenum fed by only 1/2 of the carb, and airflow at the booster is not an issue with 480+ cid and the RPM port and plenum size.
I run a 1000HP on my 489, I run a/c when its hot out and in 5th its an overall 2.36:1 final drive. I run it around town like a stocker, or will spin it up and let it roar with no downside.
I had a 770 on it for a while diagnosing an issue that turned out to be ignition-related, and it was like I was pulling a parachute with no gain in low end drivability or mileage at all. I didnt dyno, but if you told me I lost 50 hp I'd believe it, heck maybe more, it was amazing. I am not stretching the truth at all. A white knuckle ride, repeated before and after the 770 was noticeably tired above 4500 with the small carb, and both were tuned as well as I could dial them in.
Remember, hot 427's in the day ran at least 2 600's if not 715's, and you are adding 55 cubes and much more efficient airflow! How can a 780, perfect for a mild CJ motor be good for a light car and a 482?
Vizard's old rule of thumb is 2 cfm per cid, recently he has published some other discussions of carburetor sizing on a dual plane that blows away the small size belief, even on small blocks
Try a 780 if you are concerned, but for laughs, beg or borrow an 850, or even better a 1000 from HP or Quick Fuel, and do a back to back street run or even better dyno tests, you'll see. That motor needs air, more stroke, more bore, much advanced heads and intake design, why choke it?
1994 ERA Cobra, 452 side oiler, C5AE-F, Tunnel Wedge
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
