Old 03-19-2008, 11:29 AM
1Trkpony 1Trkpony is offline
Cobra Make, Engine: ERA 541, Shelby 427, TKO600
Nope did not get them out, stopped trying before I damaged anything. I got the BH centered and welded on the "washers" without the block plate to make sure they fit nice. They are actually very close to working (centering the BH) with the block plate on but to be sure I then drilled 2 holes for new locating pins at 7 o'clock and 2 o'clock and used drill rod for a very tight fit. Now it is dialed in and will not move. If I every remove my engine I can have a machine shop remove the pins and put in the longer ones and all will still line up since the washers are already welded on.
