Old 03-19-2008, 12:56 PM
rokndad's Avatar
rokndad rokndad is offline
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
I bought the polished Shelby FE covers from them and everything clears perfectly. And not one drop of leakage! The chrome stamped steel FE covers I had before leaked like sieves. Rubber gaskets. On the cast covers I used Fel Pro rubber impregnated cork gaskets from Summit, sealed completely to the new covers with gray RTV, let sit overnight, and bolted them up.
Since it appears you also have a KC 482, you must have the same heads and pretty much the same valve train as I do. Call Keith first. I seemed to luck out.
