  #32 (permalink)
Old 03-20-2008, 12:21 AM
Keithc8 Keithc8 is offline
Default oil in radiator
I have been out a few days with the family since it is spring break for the kids here. This is the first I seen of this but did talk with Rob about it today. The only thing that I can think of at the moment is a possible crack in an oil galley. It might only open up after the engine has gotten to operation temperature. These things are hard to check for and about the only way would be to get the engine up to about 200 and then drain the oil out of the pan and pressure test the cooling system to see if any water runs out of the block. I do not believe I have seen a 351W block cracked from the oil galley to the water passages. About the time we think we seen it all we see something else.
I would do as suggested and flush the radiator good and then the engine again for a while to see if the oil shows up again. I would assume that the car has been where nothing could have froze over the winter. Let me know what you find out. Thanks, Keith Craft
Keith C
